TwinTurbo.NET: Nissan 300ZX forum - Sounds like it's not in Idle Mode.
Cjw3
on February 18, 2014 at 8:22 PM
Re: Forgot to mention it is not good to run the O2 unplugged.
posted by TurbodreamZ
on February 18, 2014 at 04:03 PM
Check the Ignition Timing at Idle WARM.. if it's triggered into Idle Mode, then O2's go lean.. Idle goes to 750 ( I think that is the Number ) and the Ignition goes to 15 Deg..
Cj
code 53 running out of ideas
TurbodreamZ
20:39:15 02/13/14
Get ECU talk and a Consult cable
Cjw3
23:06:46 02/13/14
I purchased the exact cable from the same seller.
SammybTT(TN)
22:25:59 02/14/14
Re: I purchased the exact cable from the same seller.
TurbodreamZ
01:05:15 02/15/14
Ok I understand your question now
SammybTT(TN)
09:38:28 02/15/14
Yep.. that is about what you are looking for
Cjw3
11:41:08 02/15/14
Re: Ok I understand your question now
TurbodreamZ
14:12:07 02/15/14
First Gauge of the four is running rich. most of the time
Cjw3
17:28:18 02/15/14
Could a bad pcv valve cause this?
TurbodreamZ
10:12:25 02/16/14
SammybTT(TN)
10:33:37 02/15/14
TurbodreamZ
16:03:07 02/18/14
Sounds like it's not in Idle Mode. -
Cjw3
20:22:57 02/18/14
It does idle properly. (n/m)
TurbodreamZ
22:26:46 02/18/14
